Hi there,
Im going to attempt to re-solder a 12v DC Charging port on a pcb for a drycal that I have.
When opening it up, I notice what appears to be either a very thin wire, or is it something leftover from painting the component?
The charging port appears to be glued on to the pcb board, which im going to have to remove, but im not sure if this is a wire that is meant to be attached and treated with caution when trying to remove the glue?
I have attached a photo to show the wire in question, and if it is a wire?
