Hello
I have designed two PCB's which utilize modem I2Cs to transmit signals at 700Mhz and 900Mhz respectively. I have UFL connectors which connect 50ohm impedance aerials to the PCB. The UFL connectors are connected to the output of the I2Cs and ground.
I have positioned the UFL connectors <10mm away from the I2C outputs and have a PCB trace connecting the output to the connector. Using this calculator (https://www.eeweb.com/tools/microstrip-impedance) and specifying to my PCB manufacturer the following paramaters:
Copper weight = 1oz
PCB thickness = 0.8mm
PCB material = FR4 TG130
and assuming Er = 3.5
I have calculated a trace width of 1.76mm to maintain 50 ohm impedance. This is somewhat hard to do given the output pins of the chip are ~1mm in width. Many aerial manufacturers call for matching circuits to be implemented on the aerial input, but the LC values will obviously differ across different PCB designs. I do not own a VNA so verifying that the impedance will be correct after manufacturing will be difficult.
I have read on various websites that provided the PCB trace length is <1/20th of the wavelength (700Mhz = 429mm & 900Mhz = 333mm), then the PCB trace impedance is not that critical? Is this true?
If this is the case, I will try to make the PCB trace 1.76mm wide but keep the length to <10mm and not implement a matching circuit on the aerial input.
Copper weight = 1oz
