PCB Routing and via and PAD
Status
Not open for further replies.
Gajyamadake
Joined Oct 9, 2019
313
I am routing all components manually. What are vias in PCB design and Why do we require in PCB deign
I made design on Eagle cad. Do I really need vias in my design
jpanhalt
Joined Jan 18, 2008
11,088
Vias connect the top surface of the board to the bottom (considering only a two-sided board).
Uses include:
1) Routing a connection that needs to change sides, e.g., to cross over another connection;
2) Connection to a ground/power/ or signal copper pour;
3) Components on both sides;
4) A mixture of through-hole and SMD components; and
5) Conducting heat from one side to the other.
View them as similar to a through-hold plated pad, but generally smaller.
jpanhalt
Joined Jan 18, 2008
11,088
I have circled two of them:
Note that the connections (routes) change from bottom to top. Consider this, you have a TH capacitor mounted on top. Soldering on the top is difficult (but can be done). It is easier to solder on the bottom, then bring those connections to the top for soldering to C3, which is an SMD. That is my point #4. The other via allows the two tracts to cross from the capacitor to Pin2 over Pin1 to the SMD.
Those are the only vias I see in that design. The other green things are plated through holes for the TH components or mounting holes.
Gajyamadake
Joined Oct 9, 2019
313
I think this is best PCB as per my knowledge. Will you suggest any improvement on placing and routing ?
jpanhalt
Joined Jan 18, 2008
11,088
It's hard to comment as the routing is pretty straight forward. It could be made smaller, but that may not be what you want to do. Do you want the LED on the backside (it's mirrored)? Of course, since it is just two pins, it can go on either side, but the silkscreen will be on the back. Even though 24 mil might be a good minimum for route width, I would still go thicker as in the example you posted (Post #3).
Status
