Need HELP with routing MIPI-CSI 2 using two-sides connector
funda
Joined Nov 13, 2025
Are there those who have installed mipi-csi lines on double-sided connectors? What is the best way to route vias on this connector? The problem is that I can't get the d+ and d- lines to be of uniform length from the connector pin to the vias. Also, d + and d- from the connector to the via hole are <1mm long, respectively, the gap in the differential pair is 1mm+.
I also can't space the vias further apart because then the gap in the d+ d- pairs will be even larger.
How can i route it correctly, any recommendations?
What are the best practices for routing diff pairs on such connectors?
PS: the connector is
FH35C-31S-0.3SHW(50)
