du00000001
- Joined Nov 10, 2020
- 201
What the guy is handling is a standard "FPC" flexible board. These are basically fabricated just like ordinary PCBs, so the conductor is Copper - maybe tinned or with a silver layer. The main difference is that the traces are covered by cover layers to prevent shorting. (With some expertise, you can even peel off the cover layer.)
If you're very lucky, the carrier material would be Polyimide (aka Kapton), which can sustain temperatures up to 350 °C or so. Won't melt when soldering with moderate heat.
