PCB of audio amplifier TDA7297's notes before manufaturing
duykwe
Joined Nov 17, 2023
71
Hello everyone, I am making an audio amplifier with TDA7297, I've finished the PCB layout and wiring already and soon will manufacture it. Before that, I hope you guys can give me some advice or anything that I have to be mindful about, so I can make sure it can work after manufacturing. Here are the schematic and the pictures of the PCB. If you guys need more information about the PCB please tell me. Thank you guys so much!
LowQCab
Joined Nov 6, 2012
5,102
It's not a question of "did I do it right",
it's more a question of how much crazy abusive testing do You expect it to survive.
You are the one trying to create a product,
what are your design goals / specifications ????
duykwe
Joined Nov 17, 2023
71
I mean that to make sure it works properly in normal conditions. Like, I'm scared there are some factors like the way I wired the components or the leads too close to each other that can affect the signal integrity.
duykwe
Joined Nov 17, 2023
71
Also, is polygon pour with the net GND affect the input or output signal of the circuit? Hope you can help me!
AnalogKid
Joined Aug 1, 2013
12,256
Linear audio power amplifiers are weird. They don't just require power supply decoupling - they demand it.
1. Increase C5 to the value shown on the datasheet.
2. Move both C4 and C5 to be closer to U1. The 100 nF should be as close as possible to a power pin, with the electrolytic jammed up behind it. Even better, since you have two power pins and a ground plane, is to double the decoupling. Put a capacitor pair next to each U2 power pin.
ak
