In one of my application i need to charge/Discharge 12V battery upto 50A . So need what is the thickness of pcb and track width to support high current and how can i increase the current with less space available over PCB.
Search "PCB Calculator". Many PCB makers have a on line tool. current calculator
You can see what happens with 1oz verses 2oz copper.
Use both sides of the board if you can.
Look at temperature rise. 20C?
I've seen some higher current distribution panels built on a PCB, and one thing to remember is that the wide/thick tracks are on both sides and also have dozens of vias between the top and bottom trace (same line, current split between two layers). That is, to handle high current, the board used both sides of the board to make a parallel trace top/bottom with vias between them. That trace was about 1/2" wide on both sides, but not sure of what copper weight it used. It was rated for around 35A
