This the board in a freezer that has a high temperature alarm beeping sound as the temperature rises above a set point. Can anyone identify where the beeping may be coming from and how I can disable it? Thank you.
There may be loose bits in between so lift the PCB off the cover carefully and note where everything is ready for reassembly.Ok I see what you're saying. I will try to disassemble it. Thanks for your help.
I use a piece of cardboard and disassemble in a line along the board. Then reverse the project to assemble.As a hint I use my mobile phone cam to take shots as I disassemble some pieces of equipment, very helpful memory jogger where all the bits go back together.
by Robert Keim
