Assuming you have Windows XP, like n9352527 says you can boot using the XP cd and go to the recovery console. You should look at the Microsoft knowledge-base article on this error (ref: http://support.microsoft.com/kb/318728/), this is for Windows 2000, however it is likely that it will be applicable to Windows XP.Thank you Dave.Can you please,post the procedures how to fix this problem?
There's always one!!Problem 1) You're running windows
you can check your ram's memory if it has any problem it give u queer messages during bootcan anyone answer this question?
what is the most common cause of this message at boot up? "NTDLR is missing, press any key to restart!
many thanks
ahmed arafa
