Hail and well-met all the mavens who are here. Thank you in advance for helping me with the terribly simple question. Circumstances are this 1:80 amp DC 12 volt charging inverter in a trailer. 2: 24 volt stackable 1000w solar inverters. Question can I pull power at 24 volts by appropriately wiring battery from a system that is charging at 12 volts and running at a nominal 14.2 volt.
As I said in the title I know this is pathetically simple but I cannot see why it can't be done. Eventually I will switch to all 24 volt Tech 2 power inverter as I complete the transition to a total solar energy system. But for now I have an excellent inverter charger albeit at 12 volts.
My thanks in advance and humble apologies for the gross ignorance that lies behind this question. but as my mama said you can educate ignorant you just can't fix stupid.
Please all have a safe day.
Jeff KG7TXI
Jeff KG7TXI
