Pasting spreadsheet tables - how do I do it?
RogueRose
Joined Oct 10, 2014
375
I had about 6 colums and 30 lines of a spread sheet with the labels on the top row and then all number below. somehow I was able to paste this into the message body and it held formatting! The odd thing is that it showed up under the "create Thread" and "upload file" section as a png, which I never saved it as such (it wasn't even saved at that point). Somehow it pasted all the data from the spread sheet (using LibreOffice Calc).
I thought there was an icon that showed a spreadsheet or table or something, but it seems to have disappeared after inserting that table.
Anyone know what's going on?
bertus
Joined Apr 5, 2008
23,005
Create a new spreadsheet and attach that as a file to the post.
The .odt extention of openoffice/libreoffice is supported.
Bertus
RogueRose
Joined Oct 10, 2014
375
Bertus
Does this show it as a file attachment or does it incorporate it into the message like pasting it in (or adding an image in the post). That is what happened when I did it and I can't figure it out after trying for almost 30 mins!
bertus
Joined Apr 5, 2008
23,005
As far as I know there is no direct way to insert tables in the posts.
You can post speadsheets as attachment.
Bertus
Alec_t
Joined Sep 17, 2013
15,156
In situations like this it would be handy to have a dummy forum where members could experiment with various formats and data types in order to preview the effect, before posting to a main forum.
dl324
Joined Mar 30, 2015
18,463
You can already do that.
You can compose a reply to any thread and use the "More Options" option to preview. Just don't post it; you have to manually clear the text entry box or it will be remembered.
JohnInTX
Joined Jun 26, 2012
4,787
@dl324 That's something I hadn't noticed either.
If you want to try something out, consider just opening a new thread in OffTopic, messing around (nicely please) then when you figure it out, ask a mod to delete the thread.
Maybe a good sticky would be all the slick things we find out.
