Software/Spreadsheet for transformer calculation
28,575
The question is a bit unclear, and it is not likely to be in a spread sheet format. What portion of the design do you seek a tool for? Size?, Power? Frequency Response? Efficiency? Linearity? Or saturation characteristics?
My point being that transformer design is a broad area and so there are a lot of different formulas that get used.
Ramussons
Joined May 3, 2013
1,572
Guys, does anyone have any software or a spreadsheet with calculations for transformers?
For a 50/ 60 Hz power transformer, use the generic formula>
1 Sq Inch Core area = 30 VA, VA is proportional to Square of Area => 2 Sq Inch = 120 VA
Winding is ~ 6 turns / Volt
This is for E-I metal core laminations at the normal power frequency.
Not for air / powdered iron / ferrite cores.
28,575
Audio transformers are a bit more demanding than average power transformers because they need to avoid distortion. (Transformers used to be a very large part of audio power amplifiers.) And still, avoiding distortion of non-linear operation is still a big deal. Transformers for assorted other signals also have additional requirements.
LQC in post #10 is quite right!!!
LowQCab
Joined Nov 6, 2012
5,102
The particular purpose of the Transformer changes everything.
The Frequency of operation changes everything.
The Style of Core changes everything.
The Material that the Core is made of changes everything.
The Duty-Cycle changes everything.
For Mains-Powered Power-Supply Transformers,
purchase a commercially available Toroidal-Transformer, with an adequate VA-rating,
then wind your own Secondary(s).
Add Secondary-Turns until You get the exact Voltage You need.
There are general "guidelines" for other Transformer applications.
28,575
OR, for an easier to deal with arrangement, and mounting, use a "Signal" brand power transformer. Good quality and honest specifications.
Rakesh#12
Joined Aug 30, 2026
50Hz transformers or high-frequency switched-mode transformers?
I am looking for a Transformer Design Excel Sheet covering 50 Hz & 60 Hz, 3-Phase Transformers, including:
• Dry-Type Transformers
• Oil-Immersed Transformers
• Power Transformers
If you have a suitable design calculation Excel sheet, could you please share it here? If email is more convenient, I can provide my email address for receiving the file.
MaxHeadRoom
Joined Jul 18, 2013
30,881
Incidentally, three phase toroidal transformers are usually constructed using 3 1ph uniquely-separate transformers rather than on a single frame as is usually done with 3-1ph E.I. versions.
28,575
Max is correct!! I am trying to imagine a "three-phase toroidal transformer". It would require more than three axis, which gets really complicated.
Reloadron
Joined Jan 15, 2015
7,977
What transformer(s) did you have in mind? Create a spreadsheet in Excel (or similar) and add your math to your spreadsheet.
You can transform Excel formulas into static values or build electrical transformer calculations using specific Excel formulas depending on your exact goal.
Ron
MaxHeadRoom
Joined Jul 18, 2013
30,881
3ph mains transformers are typically mounted together in the same stamped laminar-constructed steel frame, but actually operate as three 1ph independant transformers.
Parkera
Joined May 3, 2016
138
I think winding all 3 windings on a single toroid would work. That way the magnetic flux from each winding would be contained within the core and be able to cut the turns of each individual winding. Of course the core would have to be sized to handle the maximum flux. The windings could be wired Y or delta.
