I'm sorry about this, but i still have absolutely no idea what to do with this circuit...
at the minute i have found:
frequency: 23.725...Hz
total current: 45.45453303uA
Xl = 7.453559924 ohm
Xc = 7.453559926 ohm
dynamic impedance: 0.1182033096 ohms
Q: 0.015858
my next step was to try and find the currents in each branch of the parallel section, so i tried to use mesh analysis for the 3 loops,
i ended up with the left loop as 45.45437569uA, the middle loop as 22.90598133uA and the right loop as 22.5483945uA which is wrong, and that was circuit analysis by guessing, as i've never been shown how to approach this with ac (only dc).
As an example of how i calculated (guessed) current in the middle loop, i came up with the equation (I2 - I1)(7.453559924)+(I2 - I3)(470) = 0
i don't know if i should be using the resistance with inductive reactance values (which i did above), or the impedance or dynamic impedance.
someone mentioned earlier that to find current i should use: I=U/R for DC And I=U/Z dor DC. what is U?
Q: 0.015858
