Output voltage linearization
Papabravo
Joined Feb 24, 2006
22,115
Hello everybody. Could you explain how the sine equation expands? Thank you.
The signals with the "hat" above them are very small perturbations on top of a "larger" operating point signal.
There is a trigonometric identity, you should be familiar with, for expanding the sin(A+B). Look it up for the proof.
Lastly terms that do not significantly affect the result can be shown to approach either 1 or or the value of the argument and can be replaced by the respective values.
Since this is Homework Help, and not Homework Done For You; you need to show us some of your own work.
