OTA Antenna modification?
SLK001
Joined Nov 29, 2011
1,549
If done properly, then "yes". If NOT done properly, then "no". In fact, if not done properly, you will actually LOSE signal strength. Adding elements quickly suffers from greatly diminishing returns. Your best bang-for-the-buck would be to add an amplifier at the antenna. I use an Antennas Direct model PA-18 amp at the antenna and reliably pull in UHF channels 65 miles away. Just be sure that you are AC coupled into the amp.
#12
Joined Nov 30, 2010
18,224
I also use an antenna amplifier which attaches right to the antenna terminals for the best available signal from the antenna it is attached to. It has voltage gain, drives several cables in my house, and removes problems rather than becoming one of the problems, for a rather low price.
frank55
Joined Dec 6, 2013
314
Thanks guys; i also use a 15DB amp with power inserter,one thing i do not use is a 300ohm to 75ohms Balun transformer at the antenna, i connected the coaxial cable strait to the antenna.
these are the channels available in my area,see link; i get most of the 65 miles,maybe with a better set up or other antenna i would get more with better Q.
http://www.tvfool.com/?option=com_wr...dfaf7c5bde9849
bertus
Joined Apr 5, 2008
23,010
JoeJester
Joined Apr 26, 2005
4,390
It looks like a CM-2020 antenna. It has a 300 ohm impedance and they included a balun for the customer to use. Without it, they cut their reception power in half.
http://copradar.com/dtv/index.html has some helpful hints.
When pointing his antenna, I'd probably point it towards CH 36. It's a nearby channel that transmits a low power (15 kW).
