oscilloscopes and wireless signals
khush44
Joined Mar 15, 2022
2
Do you think it would be possible to make a DSO with much higher sensitivity of 1 µV per division that could observe microvolt signals? If not, what would be the limiting factor and what do you think the bandwidth would need to be?
KeithWalker
Joined Jul 10, 2017
3,625
Do you have a need for an oscilloscope with 1uV/div or is this just speculation?
There are scopes with a bandwidth of several Gigs but there is very little demand for sensitivity below 500uV/div. It probably could be done, but it would be very expensive to make sensitive low noise, wide bandwidth amplifiers.
Ya’akov
Joined Jan 27, 2019
10,355
This is speculation but it is based on the title of the thread.
Receiving weak signals directly on an oscilloscope doesn't make sense. An RF front end would be used to receive and amplify the signal, then send it to the scope.
