Oscilloscope probe compensation
mike69
Joined Dec 22, 2012
83
I have a GDS1052U oscilloscope from GW Instek. In the manual is mentioned about the probe compensation.
Does it matters if I make the probe compensation with the coupling on AC or DC ?
Does the wave forms from the attached screenshots look good ?
38,504
It may not make any difference for a 1kHz square-wave, but using the DC coupling is best.
Those screenshot waveforms both look good.
mike69
Joined Dec 22, 2012
83
Thanks.
So it should be good if I made the compensation using AC coupling ?
PS I already made some important measurements and I need to know if the probes were correctly compensated using AC coupling.
Reloadron
Joined Jan 15, 2015
7,889
Yes.
Here are a few examples of an old analog scope.
Normal Compensation:
Over Compensation or High Frequency Accentuation:
Under compensation or High Frequency Attenuation:
Ron
Danko
Joined Nov 22, 2017
2,168
Theoretically you should make probe compensation with coupling on DC only.
It is important to have in view that with AC coupling signal always is distorted:
mike69
Joined Dec 22, 2012
83
I re calibrated the probes using DC coupling.
Does the screenshots look good ?
I used 2 different probes.
I alreade made, yesterday, some important measurements (power supply noise and ripple and oscillation), so I need to know if the probes were correctly compensated.
mike69
Joined Dec 22, 2012
83
I did not changed any compensation settings from the probe.
More exactly, I did not rotated any screw on the probe.
Danko
Joined Nov 22, 2017
2,168
My post was not only about compensation, but mostly about measurements with AC coupling.
With AC coupling measurements, measured signal give off its direct component, and obtains distorted form on low frequencies.
For power supply noise and ripple and oscillation measurement use AC coupling is just essential.
