Oscilloscope issue when analyzing 2 signals simultaneously
Jeanguypataterubberboot
Joined Aug 29, 2016
19
I have a Rigol DS2072. When I use both channels to measure both channels from my function generator all is well but when I connect one channel to my MFJ 269C antenna analyzer set to the same frequency as my function generator I can't view both signals simultaneously. One is fine but the other one is all distorted. Is there a logical reason why this is? Or is there something wrong with the scope?
Thanks for the help
Pierre
AlbertHall
Joined Jun 4, 2014
12,630
They may be set to the same frequency but they won't be exactly the same frequency. If the timebase is triggered from, say, CH1 then CH1 will display correctly but CH2 won't be synchronised. I don't know the menu system on that scope but on a non-digital scope you would select 'alternate trigger' which display the two channels on alternate sweeps each correctly synchronised.
spinnaker
Joined Oct 29, 2009
7,830
That is a digital scope with a USB port. Why are you posting huge sideways photos of your scope? You realize you can take very nice looking screen shots and save to USB right?
You can also download ultrascope from Rigol's website and view and save waveforms right on your PC.
Makes it a lot easier for people to view your sample waveforms.
Joined Aug 29, 2016
19
Don't have a pc hooked up near it at the moment. Just getting to know this fine piece of engineering.
spinnaker
Joined Oct 29, 2009
7,830
A PC is nice because you can get a larger image. Plus you can actually view the waveform in a data format but a PC is not needed to save an image.
Place a thumb drive in the scope.
Press Storage
Press Waveform and use the selector knob to save as Bit Map. Press knob to select
Press External/New File
You can use the knob to change the characters for a file name. Press to select.
Press Save
BMP file will be saved to the thumb drive.
Joined Aug 29, 2016
19
Press Storage
Press Save
Thanks for the tip. I'll do that next time. ;)
Thanks for the help
Pierre
The trigger event must be derived from each channel (alternately) -- as shown, the trigger event is derived from a single channel only (to wit: that presenting the static/stable display)...
Best regards and good Luck!
HP:)
