oscilloscope hookup for amp/dummy load testing
Johnny7
Joined Feb 5, 2022
20
The only schematics I can find show only a single channel being tested.
Is it safe to connect the ground clips from each of two oscilloscope channels to the corresponding "ground" (speaker lead negative) end of each resistor?
Does this violate the "single ground" rule - or is it OK since the two channels actually share a common ground?
Ian0
Joined Aug 7, 2020
13,291
It is, until you find yourself testing a bridge-tied-load amplifier!
With stereo amplifiers where the speakers return to 0V, there may be some errors, proportional to the speaker lead resistance.
You can eliminate that problem by connecting both probe clips to the ground at the speaker output sockets, but than generates a different small error as the load resistance now include the speaker lead resistance.
Johnny7
Joined Feb 5, 2022
20
Thanks for the response, Ian.
This is not a BTL amp, though the warning is much appreciated.
Audioguru again
Joined Oct 21, 2019
6,826
Some cheaply made amplifiers play the momentary levels of music and vocals well, but smoke then burn out when being tested with a continuous high level.
