Oscilloscope help for audio
shade23
Joined Oct 4, 2023
11
I am a retired electrician and am starting a small vintage audio/stereo business. I have a very strong field in controls and commercial electrical. I have a basic idea of audio units and have been able to repair analog equipment out of the fifties, sixties and seventies. A lot of units have printed circuit boards and I have been able to repair them.
I picked up a really clean Tektronix 2445B, 200 MHz Oscilloscope but the cables are missing. I could sure use some help with the correct cables for using on audio and speakers. I have used a lot of electric test equipment, but I know nothing about an oscilloscope. The manual mentions P6137 and P6133 but I really want the cables that will work for my application.
Any guidance would be much appreciated.
Ya’akov
Joined Jan 27, 2019
10,234
Welcome to AAC.
For the most part all you will need are one or two decent 10x probes. You will need to learn a fair amount to make the scope useufl. What did you plan to do with it?
Standard scope probes will work.
https://probemaster.com/oscilloscope-probes/
Ian0
Joined Aug 7, 2020
13,131
I added a divide by 10 circuit (180Ω/20Ω) connected to a BNC socket on my dummy load, and connect it to the scope (on x1) with a standard BNC lead.
34,807
If you want to do it on the cheap, you can do it with ordinary hookup cables, banana plugs on BNC coax cable, or you can DIY your own x1 probe with RG-174 coax cable. You can also DIY your own x10 attenuator as Ian suggested.
Give yourself a treat and purchase a proper x10 probe. It doesn’t have to be a recognized brand name probe. Shop around for best price.
If x1 probes will save you money, go for it. You can always get x10 probes later.
For audio work, you don’t need two channels and two probes. You can get by with a single channel.
shade23
Joined Oct 4, 2023
11
Welcome to AAC.
It is all new to me, I also have a nice RCA signal generator and I have heard you can even balance speakers, etc. It is all new and at 74 I just want to learn. Thank you.
shade23
Joined Oct 4, 2023
11
Thank you.
shade23
Joined Oct 4, 2023
11
dl324
Joined Mar 30, 2015
18,326
There's no reason why those probes wouldn't work for your application. A benefit of using Tektronix probes is that when they say a "system" has a certain bandwidth, that's the 3dB down frequency for the probe and scope together. If you use generic probes, you'll be 6dB down.
38,503
The probes that switch between 1X and 10X are handy, (post #5) since you can easily switch between the two without having to disconnect them.
The trick is to remember which position the probes are set to.
For most of you work with audio the 1X setting should be fine, but for any high impedance measurements you would want 10X.
shade23
Joined Oct 4, 2023
11
Thank you.
shade23
Joined Oct 4, 2023
11
Thank you.
shade23
Joined Oct 4, 2023
11
Thank you.
shade23
Joined Oct 4, 2023
11
Thank you.
