'Help me' to see the Audio signal in Oscilloscope
chinju mon c c
Joined May 27, 2022
1. Normally i want to convert electrical signal into audio signal.
2. By using Microphone i can able to see the electrical signal in Oscilloscope. But I can't able to see the audio signal in Oscilloscope
3. Is any method to see the Audio signal in Oscilloscope
boostbuck
Joined Oct 5, 2017
273
Oscilloscopes can only see electrical signals. That's what they do. You must first convert any signal to an electrical signal in order to see it on an oscilloscope. A microphone converts air pressure changes to electrical signals. A photodiode converts light changes to electrical signals. And so on.
What is the nature of the audio signal you want to see on the oscilloscope?
Ramussons
Joined May 3, 2013
1,333
The audio signal may be too small compared to the "electrical" signal - the DC bias.
Put a 1 nF capacitor in series with your oscilloscope probe (or select AC input) and reduce the scope vertical display range.
