Hey there,
A question I was hoping in a couple you guys can help me out with. This mainly dealing with a handheld digital 2 channel 100mhz oscilloscope. "MicSig"
So I've got this to use on my Tesla coil, I first designed one using one of those $80 handheld Chinese ones. Not bad for car use but that's about it. so now that I have this one I can actually see what needs to be seen.
So my actual scope question is what do I do when I get in these situations where I can't ground in two different places but need to? For example say on a full H Bridge you want to check the gate signal on the corresponding IGBT, if just checking one, your ground to the Collector and probing to the gate pin. If wanting to do both of these at the same time (same switch time opposite polarity) you can't ground one Probe on one collector leg and the other probe also ground on the other collector, when that Tesla turns on you would short those to IGBTs through your internal ground plane and probes.
Also please keep in mind that this is a portable handheld scope, so I don't have to worry about the Earth grounding issue, I can practically connect to my ground Gator Clips to whatever I want, obviously as long as the other is not on the opposite polarity. Lol but that's kind of my issue here with the Tesla coil and many other issues.
So my real question is this is happened to come up in a few different situations and difficulty how to surpass this, I have heard you can leave the ground open, and do a math function, but that never shows the same signal as if the ground was connected. But this issue has now come up at least 20 times in my electrical Hobby, if anyone has any tricks to help get around this issue I would love to hear any ideas, Thanks
