Oscilloscope 0V level problem, changes with Volts per division
prometei
Joined Apr 13, 2008
98
Greets,
I've been away for more than a year and have not turned my scope (OWON PDS 5022S) on for that long.
Now there is a problem. The 0v level is a bit lower than the middle of the screen when the Volts per division is set to 2V or higher, but it's ok if it's set to 1VpDivision or lower. Both channels are affected. I've attached pictures of a 1KHZ 5V square wave generated by the scope itself.
Any ideas as to what might be going on?
thanks!
OWON PDS 5022S - 1Volt per division.jpg OWON PDS 5022S - 2Volt per division.jpg
Alec_t
Joined Sep 17, 2013
15,121
Presumably some component common to the two Y-amps (assuming there are two, rather than a multiplexed amp) has drifted in value.
38,545
Does the zero position change when you switch ranges with no input?
If not, then the generated square-wave may have a small offset or it's a function of the top of the waveform being off scale.
