I think we already have potentiometer with very good tuning option (resolution):I am also attaching the potentiometer file this time. May be you can get better tuning option.
Correction: Signal is DC voltage with small 32 kHz pulsations on top.Sir the current through R19 should be a DC signal, Right? (Please correct me if I am wrong).
Then why the current is in the form of pulses.
After amplification by U3, these pulsations produce in R19 current with 270 uA amplitude.
Potentiometers can not help, because every subcircuit is designed with errors.Tuning potentiometers also do not help.
Even if circuit will well redesigned, it will not work properly, because current, consumes by circuit, should be about 3 mA (lower than 4 mA),Can you achieve this target by using given circuit diagram. 'Get DC signal (4 to 20mA) through load resistance by variation in differential capacitor'.
but now this current is about 10mA. So, range of measuring current may be 11...27mA, but not 4...20mA.
If minimal source voltage will 18V (24V-Vline_drop-Vload_drop),
then circuit should consume overall power not more then 18V*3mA=54mW, only!
Ask your designer about such possibility.
