BillOHumpty Dumpty (in rather a scornful tone) said:'When I use a word,it means just what I choose it to mean neither more nor less.'
secondedI am curious--Is there a way to set up a poll on this forum? I think it would be interesting to find out how many people do it one way or the other. What do you all think?
Ah! Now I get what you said (so plainly too).I'm not sure Ernie. Where did I say:
\((A \cdot E)\cdot F \ \neq \ A \cdot (E \cdot F) \ ?\)
I think you have made a fundamental error here Bill....
Association by parenthesis is an important concept in mathematics, particularly in applications. Consider a physical system where the unfolding of events requires one expression in the model to be written
\(A/(B/C)\)
Then, converting that to:
\( A \cdot (E \cdot F) \ \ \ \ \ where \ \ E=B^{-1}, \ \ F=C^{-1} \)
Well a word means;Humpty Dumpty (in rather a scornful tone) said:'When I use a word,it means just what I choose it to mean — neither more nor less.'
I agree with your calculations here, but its not what I'm saying. You are missing my point and I honestly do not know how else to express it. I need to remove myself from this thread.I think you have made a fundamental error here Bill.
If we are discussing that multiplication can be used in place of division (re my argument in post #99) then;
(2/2) is NOT (0.5*0.5) !!
The division is an operation carried out on the denominator ONLY, not on both numerator and denominator. The division is a property of the denominator as the ONE action performed is; /denominator.
So;
(B/C) = (B /C) = (2 /2) = (2 *0.5)
That is an accurate conversion.
So if you properly convert your example of A/(B/C), (I will use decimal numbers not fractions);
A/(B/C) = A /(B /C) = 2 /(2 /2)
= 2 /(2 *0.5)
= 2 *(1 /(2 *0.5))
=2 *(1 /(1))
=2 *1
=2
and 2 /(2 /2)
= 2 /(1)
= 2
So if you convert all the division events to multiplication events it works! As it must because division and multiplication are generally identical in such simple examples... Like this one; 48/2(9+3)
Bill, PLEASE continue! I must have misread your point completely.I agree with your calculations here, but its not what I'm saying. You are missing my point and I honestly do not know how else to express it. I need to remove myself from this thread.
Again this is probably due to my ignorance of proper math rules but I don't have any problem solving post #95.Bill_Marsden said:I liked the proof on post #95, it pretty much covers why you can not treat multiplication and division as equivalent functions.
I agree entirely, I would never even have considered those 2 to be the same expression and was surprised at the comparison!... What I was trying to say was the A/B/C is not the same expression as A.E.F (where A.E.F is as I described)
I think this is getting to the nuts and bolts of it. The way I see it; (A/B)/C and A/(B/C) are two different processes and will produce two different results. But both work and both can have divisions and multiplications exchanged within them, showing the requirements of divide or multiply do not force either version to be right or even "better".... and that it is incorrect to assume you can always replace division factor with multiplication of the reciprocal. While in certain cases the results will be equal, it changes the behavior of the expression under association.
Before the advent of computers/calculators with their single line input and the resultant need to linearize equations, there would have been only one interpretation of:If we knew the original reason why A/B(C+D) is required to be considered as A/(B*(C+D)) it would be able to see if this reason still exists in modern calculating examples or if it is just a carryover from the days when fractions needed to be transposed on blackboards.
48/2(9*3) is an expression begging for evaluation. To evaluate such, we should all follow an agreed upon standard. BillO took the trouble to actually find such a standard published by accredited body.So much for math being the universal language.
Yes, two.Regis Philbin said:Is that your final answer?
