OrCAD output Netlist can run... where?
egoot
Joined Sep 28, 2017
Hey, All,
After some blood, sweat, and tears, I have pleased OrCAD enough to get it to generate the netlist for pSPICE... but it was the free pSPICE lite from Cadence, and so PSPICE summarily rejected it because I have "too many nodes."
Expletive. The full version is $2000 and a grad student's time is much cheaper.
So, my next steps are either:
1. Starting over in the free trial of Simulink.
2. Starting over in the free LTspice...
BUT before barking up all of THOSE trees, I was wondering if any of you knew whether I could take my netlist generated from ORcad, and use it in any of those (or other) programs. It sounds like I could download SPICE itself (https://embedded.eecs.berkeley.edu/pubs/downloads/spice/index.htm) and maybe run it there? Has anyone done that?
I'm looking for some guidance.
For reference, my circuit (photo) is attached, and the netlist is as follows:
** Creating circuit file "OMFG.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of C:\Users\........\AppData\Roaming\SPB_Data\cdssetup\OrCAD_PSpice\17.2.0\PSpice.ini file:
.lib "nomd.lib"
*Analysis directives:
.OP
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source NCSUCIRCUILT
R_R1 N14609 N14691 10000
R_R4 N14711 N147031 10000
R_R2 N14549 N14609 10000
R_R3 N14609 0 10000
X_F1 N16691 N19891 0 N14691 SCHEMATIC1_F1
V_V4 N15145 0 15Vdc
V_V5 0 N15141 15Vdc
V_V6 N15242 0 15Vdc
V_V7 0 N15280 15Vdc
V_V8 N15823 0 15Vdc
X_F2 N147031 N16691 0 N15823 SCHEMATIC1_F2
V_V9 N14549 0 15Vdc
C_C5 VIN N14609 1n TC=0,0
C_C6 0 N14711 1n TC=0,0
R_R5 N15823 VOUT 10k TC=0,0
X_U3 N14691 0 N15145 N15141 N14711 AD743/AD
X_U4 0 N15823 N15242 N15280 VOUT AD743/AD
X_D1 N19891 0 D1N5765
V_V10 VIN 0
+SIN 0 5V 1k 0 0 0
.subckt SCHEMATIC1_F1 1 2 3 4
F_F1 3 4 VF_F1 0.5
VF_F1 1 2 0V
.ends SCHEMATIC1_F1
.subckt SCHEMATIC1_F2 1 2 3 4
F_F2 3 4 VF_F2 0.5
VF_F2 1 2 0V
.ends SCHEMATIC1_F2
**** RESUMING OMFG.cir ****
.END
ERROR -- EVALUATION VERSION analog Node Limit (75 Nodes) Exceeded!
ABORTING SIMULATION
**** 09/28/17 11:10:49 ******* PSpice Lite (March 2016) ******* ID# 10813 ****
** Profile: "SCHEMATIC1-OMFG" [ C:\Users\Matt\Documents\pSPICE\NCSUCircuilt-PSpiceFiles\SCHEMATIC1\OMFG.sim ]
**** JOB STATISTICS SUMMARY
Node counts:
Top level (NUNODS) = 13
External (NCNODS) = 84
Total (NUMNOD) = 84
Total device count (NUMEL) = 166
Capacitors (C) = 18
Diodes (D) = 30
VCVS (E) = 14
CCCS (F) = 6
VCCS (G) = 18
Current Sources (I) = 7
JFETs (J) = 4
Inductors (L) = 2
Resistors (R) = 34
Voltage Sources (V) = 31
Number of subcircuits (X) = 5
Analysis statistics:
No. total time points (NUMTTP) = 0
No. rejected time points (NUMRTP) = 0
No. iterations (NUMNIT) = 0
Load Threads = 1
Runtime statistics: Seconds Iterations
Readin = .14
General setup = 0.00
CMI setup = 0.00
Setup = 0.00
DC sweep = 0.00 0
Bias point = 0.00 0
AC and noise = 0.00 0
Total transient analysis = 0.00
Output = 0.00
Overhead = .33
Total job time = .14
Quinn124
Joined Apr 12, 2019
Hi, came across this thread as I have a problem with the circuit that I’m trying to implement. I have the error “analog node limit (75 nodes) exceeded”. I’m trying to create a 2nd order Bessel filter cascaded 4 times to get an 8th order. So there are a lot of components and nodes involved. How can I create my circuit without this error? : (
djsfantasi
Joined Apr 11, 2010
9,237
This thread is almost two years old. You really need to start a new thread. Posts like these have a name - necroposting - and are generally frowned upon. Do yourself a favor and start your own thread.
eetech00
Joined Jun 8, 2013
4,724
Hi
Are you attempting to use the pspice net list in LTspice?
If so, should work as long as a model for the opamp exists in LTspice
eT
