OR gate for 230V
code4fun
Joined Sep 25, 2014
5
Hello all,
Is there a IC or a way to detect from different input wires if the 230V is present and output it for driving a load without doing AC/DC and comparing the inputs ? Basically an OR gate but for AC
Cheers
Papabravo
Joined Feb 24, 2006
22,082
Hello all,
Cheers
NOT that I am aware of.
ETA: At least with an integrated circuit.
BobTPH
Joined Jun 5, 2013
11,514
I think you have two sources of 230V and want either of them to power a load, right?
You can do this with a 230VAC coil DPDT relay.
ElectricSpidey
Joined Dec 2, 2017
3,334
Are these two sources in phase and at the same voltage?
You may want an Exclusive OR (XOR), or derive the load power from a source separate from the detected lines.
