Optimizing browser-based Mahjong for lower-powered boards / SBCs
samsuk63
Joined Sep 28, 2025
Hi folks,
I’ve recently been messing around with running browser-based Mahjong (the solitaire version) on lower-powered boards / single board computers (Raspberry Pi variants, Orange Pi, etc.). The idea was: after a long day of circuit debugging, running a light game to relax — but without overtaxing the board.
Here are some observations and modest suggestions; maybe some of you have better tricks:
Use a minimal browser engine (e.g. Chromium in kiosk/light mode, or a WebView) rather than full Chrome with all the bells. Less RAM / GPU overhead helps.
Disable or reduce animations / transitions in the Mahjong implementation. Every fade, slide, sparkle costs CPU.
Preload / cache tile positions / board layouts so that the game can skip heavy DOM / redraw work on every move.
Use simpler tile graphics (low resolution, fewer layers) to reduce rendering burden.
Throttle frame rate (e.g. cap at 30 fps or even 20 fps) — visuals still smooth but much lighter on GPU.
Possibly run the game in a dedicated process or tab so that background system tasks (e.g. watchdog, logging) don’t interfere.
I wouldn’t expect full desktop speed, but on modest boards it becomes playable and relaxing, not frustrating.
Has anyone else here tried running Mahjong (or similar browser games) on SBCs or weak hardware? Any further optimizations or tricks you’d recommend (e.g. GPU acceleration, hardware layers, offloading)?
Looking forward to hearing your ideas.
