Optimizing TL431
engr_david_ee
Joined Mar 10, 2023
364
I am considering the attached circuit TL431 as a current source. I am wondering how do we solve Iout ?
I found this circuit at Figure 7 under the link
https://www.ti.com/lit/an/snoaa46/snoaa46.pdf
The datasheet of TL431 can be found from here.
https://www.ti.com/product/TL431LI-Q1/part-details/TL431LIAEDBZRQ1
Iout = Vref/Rs + Ika
If Rs = 100 Ohm
Vref = 2.495 V (according to datasheet)
What is the value of Ika ?
How do we chose R1 ? If depend on Vcc, Iout, hfe, Ika. What is hfe ? Is that related to transistor NPN shown in the circuit ?
ericgibbs
Joined Jan 29, 2010
21,637
Hi eng,
The hfe is the low current gain value of the BJT, linear region of operation.
E
clip:
The hFE of a transistor, often called the DC current gain or simply the beta (β) of the transistor, is a measure of how much the transistor amplifies the current from the base to the collector in a bipolar junction transistor (BJT). The hFE is given by the ratio of the collector current (Ic) to the base current (Ib).
https://electronics.stackexchange.com/questions/226443/hfe-of-transistor-in-active-region
