Opinion about Design LTSPICE
Kierip Sab
Joined Mar 11, 2016
7
Dear Tinkerers, Electronic Engineers,
I was wondering if I could get an second opinion about the follow circuit.
It has the functionality to be driven by a 1.5V source/beaglebone black.
amplifies it to 3.0V then level shifts it. to 1.5 ... -1.5V.
I am using the LT1354 for the whole circuits because of the slew rate of the Square wave.
the filter is set on 1KHz
noise ratio looks nice,
FFT is below -20dB:D good enough for starters.
So what can I do to optimize the circuit?
I placed caps where they are needed.
I tried changing the Offset and the amplification, Tried to remove R7 which is required elsewise it will start to oscillate.
kind of tried the In put output matching, but R3 has to be a potentiometer, and R13 and R5 as well.
what can I do to optimize it even more?
I am so excited:D
sincerely yours
Bastiaan Pierik
Kermit2
Joined Feb 5, 2010
4,159
No one with any common sense will download a ZIP file to their computer when it comes from an unknown poster who only has one single post.
Upload the file itself, so the .extension is visible and people will open it and try to help you
Kierip Sab
Joined Mar 11, 2016
7
Just upload the .asc file directly.
You didn't answer my question.
:S ok, Ill explain... the All About Circuits doesnt allow me to post the ASC file.
please check for yourself. The only way to upload it was to Zip it. and 7zip didnt work either thats why I had to shift to a standard ZIP file. I hope this explains enough to go around your paranoia. and get a decent Virus Scanner, Registry cleaner or whatsoever if you dont thrust me. I am not the IS, but I am the Devil incarnate and I would like to take over the world and infect you all. My other name is Evermore99 for somehow this website didnt allow me to log me in twice and I have same as your paranoia, to much passwords.
Good Morning and have a nice day!
38,772
Below is a random .asc file I just uploaded using the "Upload a File" button at the bottom of the post.
It's not that I don't trust you, I just don't like the extra pain of messing with ZIP files.
ScottWang
Joined Aug 23, 2012
7,505
Welcome to AAC.
Please be polite to the helpers, they spent their free time to help you with no pay.
You just came here to asked for help, and many things you don't know, as crutschow described is quite common here, if you want to get help, please follow what the helper said and you also need to post a gif or jpg file as 800x600 for your circuit, some helpers may not install the LTspice, but they still can help you, and that is very common to attach the images could let every members can see as jpg or gif.
Alec_t
Joined Sep 17, 2013
15,156
Ok, so now we've got the asc file. But, as crutschow asked, exactly what is your circuit supposed to do? You seem to be trying to filter out >1kHz components from a 50Hz square-wave input? How would you define 'optimum' in this context?
Kierip Sab
Joined Mar 11, 2016
7
Welcome to AAC.
I know I know, I did misbehave.
ok I did post a schematic.
there were some problems with the uploading.
Kierip Sab
Joined Mar 11, 2016
7
wel
Ill enlighten.
I would like to heat up Peltiers and control it by a feedbackloop
I would like to drive from an DAC a 0 till 1.5V signal then amplify it, level shift it filter it and then in a max8521 to 1.5 till -1.5V max.
there are a lot of spikes on the square wave pulse, which are of higher frequencies (I believe it was something with the impulse response and Dirac function).
based on the step response of the max8521 I placed the filter on 1ms/ 1KHz.
what I was looking for was advice, because I have never build a circuit like this before.
things I know are:
Filtering on the VCC and VSS are 0.1uF Tantalum + 1uF or MLCC's.
guardrings around the +- of the opamps.
what I dont know is how to optimize this circuit for longterm stability, Low drift and less Calibration.
are there more recommendations how to inprove the circuit, based on Noise and FFT?
I tried placing the filter, and level shifter in various positions
the Flank of a squarewave pulse how steep should it be, because of the opamp slewrate?
which other opamps are adequate or better than the LT1354?
sincerely yours
and thank you for your time.
