Hello
I have designed an inverting circuit with a power OpAmp from Apex Microtechnology - PA09 which has high slew rate of 200V/µs. I have used their evaluation kit and made all the leads small, bypassed the supplies and have good ground plane. However when I operate the OpAmp with a minimum power supply of +12V and -12V(according to datasheet) and give a ground input, the output oscillates with a waveform similar to sinusoidal with 14Vp-p @2.2MHz. Does anyone know what is the reason for this oscillation.?
(I have attached my circuit diagram)
