Op Amp Output Ripple
ion beam nerd
Joined Jan 26, 2015
2
Dear All,
I've built a simple op amp summing amplifier using an LM358 (see attached). The circuit is used to control the electrostatic scanning plates for a charged particle beam. A saw-tooth function (1 kHz) is applied to one of the summing inputs and a DC offset is applied to the other. However, the output from the op amp has a "ripple" artifact (see attached photo's). Has anyone ever seen this before, or see anything blatantly wrong with the circuit? (I'm a physicist, not an electronic engineer, by training so please be kind!)
Cheers
34,829
Please show the X and Y scale units and zero level of the oscilloscope.
Did you forget to ground the two 10k resistors of the pseudo split supply in the circuit schematic as well as the actual circuit?
