hi Bordodynov,Hi abc77.
I have offered you an electronic circuit with unipolar power supply and with voltage ranges of 5 to 30 volts.
See #18.
You can use other opamp. If you understand how my circuit works, then you can simplify it at high voltages.
the signals to each inputs are differential signal, does your signal source represent differential signal, 4 volt peak to peak centered at 2.5V?
