op-amp opa2134 single supply question
abc77
Joined May 10, 2017
59
I want to build LPF using opa2134 as shown in PCM1789 datasheet(attached is picture).
What would be the supply voltage(s)? OPA2134 seems to support single supply voltage, if so can i use 5V for this?
OBW0549
Joined Mar 2, 2015
3,566
I want to build LPF using opa2134 as shown in PCM1789 datasheet(attached is picture). What would be the supply voltage(s)?
The circuit you provided would almost certainly be operated from +/-15V supplies, to accommodate the input voltages shown.
No. Looking at the data sheet, it's clear that neither the Input Common-Mode Voltage range nor the Voltage Output range are adequate for 5V single-supply operation.
AnalogKid
Joined Aug 1, 2013
12,120
The data sheet says +/-2.5 V right on the front page, but the inside data indicates that this works only for a very low input voltage and relatively little gain.
Datasheet: maybe.
Real world: no.
ak
kubeek
Joined Sep 20, 2005
5,796
LM741 is almost 50 years old now (introduced 1968), and it won´t work with 5V supply, more like +/-15V. Use some modern part if you want modern supply voltage :)
abc77
Joined May 10, 2017
59
i am failing to understand, where does the ground connected to capacitor go? J1 is the power supply for op-amp
kubeek
Joined Sep 20, 2005
5,796
Like I said, there is no way to use TL072 with 5V supply voltage. You would need another circuit to generate either -5V (such as ICL7660), or a boost converter to generate +10V out of the +5V you have.
abc77
Joined May 10, 2017
59
I meant if I use 10V supply how to connect TL072 to generate power supply rail for OPA2134? can u provide schematic?
Bordodynov
Joined May 20, 2015
3,431
Hi abc77.
I have offered you an electronic circuit with unipolar power supply and with voltage ranges of 5 to 30 volts.
See #18.
You can use other opamp. If you understand how my circuit works, then you can simplify it at high voltages.
