[Op-Amp] current for max. output swing
krlngc
Joined Dec 9, 2013
11
Hi all,
For the op-amp circuit in attachment i'm asked to find the \(I_3\) current that renders the output swing maximum and the \(R_E\) that allows input swing between -1V +1V. The circuit parameters are given as;
\(V_CC=5V\)
\(V_EE=-5V\)
\(I_1 = 50uA\)
\(I_2 = 500uA\)
\(R_L = 1K\)
I think that\(I_3\) sets the bias point for Q7 and determines the transconductance. In small signal case, the positive half-wave of the input will cause the \(i_c\) to flow over \(R_L\) and the negative half-wave will result in a negative current over \(R_L\) in order to complete \(I_3\). However I can't go any further. How can I make any comment about the max output swing? What should be my approach on this question?
Thank you for your help.
krlngc
Joined Dec 9, 2013
11
I can't really tell what drives Q7 to cut-off. A significant rise in \(V_E\) can reverse-bias the BE junction maybe ? Is this my upper limit?
Jony130
Joined Feb 17, 2009
5,598
Q6 can cut-off Q7 transistor. And when Q7 is in cut-off, you will get maximum negative voltage swing.
But on the other hand when Q6 is cut-off you will get the maximum positive voltage swing.
krlngc
Joined Dec 9, 2013
11
I see now. But how can Q6 cut-off Q7 ? By stealing all the current that I2 provides?
Thank you.
