Sorry about that. I needed to submit the solution today and couldn’t figure it out. Can you verify if what I’ve done is right? ThanksToo many unknowns, you need to give us something to work with.
Post your solution attempt.
EDIT: I thought this circuit looked familiar. You have started 4 threads for the same simple circuit. What's up with that??
https://forum.allaboutcircuits.com/threads/current-source-design.144632/
https://forum.allaboutcircuits.com/threads/current-source-design.144633/
https://forum.allaboutcircuits.com/threads/current-source-design.144639/
If the emitter has 30 V on it, what would the voltage at the base be?Sorry about that. I needed to submit the solution today and couldn’t figure it out. Can you verify if what I’ve done is right? Thanks
What is the purpose of R1? Even an opamp with a rail-to-rail output couldn't get to it's positive supply; assuming you could find one that would operate at 35V.I assumed Vin to be 30 and Vcc = 35
We won't do the work for you; it's you're homework.I needed to submit the solution today and couldn’t figure it out. Can you verify if what I’ve done is right?
