It says 7-12mV in ambient air, which would be 20% oxygen (more or less).I can't really figure out how the output voltage relates to the oxygen concentration.
Of course we don't know how linear that is from 0% to 20%.
It does specify accuracy and linearity at 3%, but 7mV to 12mV in ambient air is 9.5mV±26%.It says 7-12mV in ambient air, which would be 20% oxygen (more or less).
Perhaps the absolute offset, not so much, but certainly the offset drift with temperature could be.I don't know why we were all worrying about 3mV offset error!
Hi,I don't know why we were all worrying about 3mV offset error!
I would strongly recommend against doing this with a homebuilt circuit, especially given the very limited understanding of circuit design indicated here. This is life critical stuff. Would YOU be comfortable having someone you cared about getting their nitrox tanks from someone that was using a DIY circuit designed by someone that has little to no experience designing circuits? Are you going to be comfortable that their DIY circuit is going to be good enough as the temperature changes? That it is going to be good enough after months or years of use without being certified or calibrated? That it is going to be good enough as the battery voltage fluctuates?
This is a reasonable objective and approach.Thanks for all your thoughts I completely share with you, Wbahn.
For now, I'm starting this circuit from its very basics, learning to know the different elements it will be composed of and what their gotchas I'll need to discover.
Even if I make it, it doesn't mean I will be using it without having a "commercial" (certified or whatever it is) analyzer in parallel.
As many of us, I want to understand how it works, what it needs to do so and how reliable it may be. All this may also help me to understand why those commercial analyzer are so expensive. BTW, I own a commercial analyzer (see picture in previous post).
