Hi there,
I'm using the first time an oxygen sensor (Oxiplus A OOA101). It's output is linear in millivolts, typically between 7 and 13 mV by common air (21/79).
To be able to use it with a µC, I need to amplify its signal by a factor of 100 (0..50mV > 0..5V).
Since I'm not used to with Op Amps, I designed the circuit with FALSTAD (https://www.falstad.com/circuit/) simulator and it looks okay here (I attached the circuit file to the post):
But when I build this circuit, I get no voltage on the output.
The pot is 100Ohms.
I tested the circuit with some op amps I have in the drawer (LM393N, MCP6291, LM358N) but non will give me a "positive" result.
What am I missing...
Thanks for any help ;-)
Roger
The pot is 100Ohms.
Roger
![2023-09-10 22_22_56-AMPLI-OP_MCP6V11_zero-drift.pdf - [MCP6V11_1U_2_4 Data Sheet] - SumatraPDF.png 2023-09-10 22_22_56-AMPLI-OP_MCP6V11_zero-drift.pdf - [MCP6V11_1U_2_4 Data Sheet] - SumatraPDF.png](https://forum.allaboutcircuits.com/data/attachments/290/290137-a22a3c5868696159c1379dbbf1e9e852.jpg)
