Hi Guys, hopefully someone can shed some light on this problem I'm having. Here goes:
I have built a 10 step sequencer for a synthesiser. The sequencer is from the MFOS website and has been tested so it should work fine, however, this is not the case for me. Everything seems to work on the sequencer except for the internal clock, (integrator, U3-A, followed by a comparator, U3-B). I am 99% sure this is where the problem is. I have also built the circuit again on a breadboard to troubleshoot. The only problem is I'm getting exactly the same results, the integrator is not outputting the expected ramped wave. Ive hooked up the integrator output to the scope and all I'm getting is a straight line. I have also checked the outputs of both the integrator and comparator with a DVM and both outputs are saturated to the positive supply, although the comparator is never going to work without the integrator anyway, so my focus has been on the integrator for this reason. Here is the schematic and the outputs that should be present:
As I say everything else seems to be working fine its just not automatically sequencing but I can step through the sequence manually with the step button.
Any help with this would be greatly appreciated as I don't know what else to try now.
