In this design of a Tesla coil the creator talks about which IGBT he used and said he uses the FGA60n65 because he can run it at around 300a but I don't see how that is possible since the primary capacitor(CPRI) is 68nf and the primary coil is around 3 turns of wire so a fairly low inductance. The resonate frequency of the Tesla coil is approximately 300khz so using the reactance formula for a capacitor(I am ignoring the inductance because of its low value will not have much of a affect on the reactance) I find a reactance of around 7.8ohm. The max voltage of the system is 170 volts(Mains 120v rectified) and is passed through a half bridge so the voltage the primary will see is about 85volts so the max current can only be 10.9amps. Is it possible for a system like this to ever reach a peak of 300a if so how?
The creator talk about the design at this webpage
http://onetesla.com/tutorials/drsstc-bridge-design
