I'm looking for a circuit that will connect to a single on/off switch and will send a single pulse when the switch is closed, then another single pulse when the switch is opened. There will be a time delay between the events, but that is controlled externally to the circuit.
There are many 555 circuits that will do the above with two momentary switches but I have to do it with one.
The application is for a device that assesses low functioning individuals by starting a cd player track then turning it off after a time period. The idea is to see if the patient grasps the connection between a button and the resultant action, by restarting the song with the button. The front end is a standard switch latch and timer device used in timer mode. On a button press it closes a switch for a set delay then opens it. As a CD player expects a momentary button press to pause, then another to play, the switch latch and timer does not do the job by itself.
Any advice will be appreciated.
