On Demand Water Heater
Status
Not open for further replies.
R!f@@
Joined Apr 2, 2009
10,014
I feel so stupid,I said it looks a reed sensor but never occurred to me to try the it switch with a magnet.
It was a reed sensor. The inlet has a moving part inside. It was not working, so I took it apart and gave a little shock and the thing inside started to rattle.
Now even a little blow switches the heater.
Nothing was broken. Just dirt inside the valve.
Dirty water, Go figure.
Thanks guys.
Another job well done.
But I was hoping to μC it to make it snazzy. But since Sgt could not spice it and me not having a scope, I thought I'll let it go for now.
I did measure the heater voltage though.
At minimum setting I get 115VAC.
So it varies from 115 to 220VAC.
But like to know tht is this an efficient way to control power. This is rather simple method and the mostly used.
I have seen ppl using μC's to control the triac.
What would be the difference from these two methods ?
What effect would this have in the cost, meaning the electricity consumption and the bills
SgtWookie
Joined Jul 17, 2007
22,230
It seems to me that the method being used is pretty simple and reliable. Just keep the water coming into the heater clean. You should install a filter before the inlet to prevent this problem from recurring, leaving instructions to change the filter regularly.
hgmjr
Joined Jan 28, 2005
9,027
I agree with sgtwookie, a filter would be a good idea. Otherwise you are going to find yourself frequently servicing the unit to keep it unclogged.
hgmjr
debe
Joined Sep 21, 2010
1,419
Hi R!f@@, Great to see all fixed, That circuit is probably reasonably efficient, looks simmilar to a AC lamp dimmer, so the heater is actually being pullsed on/off @ has full voltage at max a lower average voltage at lower settings. Daryl
Status
