Hiya am I right this relay has pins 1-4'5-8'9-12'13-14 . 13 -14 are the coil pins am I right pin 9 is the neutral / gnd for the incoming 24vdc and pin 12 is the incoming positive for the 24vdc thanks Keith
Don't know how to do a schematic drawing and don't know how to upload one on to here .like you say it is simple I have a xpellair extractor which goes straight though the wall about 9 inch 10 inch diameter hole . Like you say I was going to take the live and negative of the extractor motor connections to give the relay 240 vac then I have a plug in adapter ( one's you plug into a wall socket ) to supply the relay with 24 vdc which will go on to power the actuator . The actuator will be on the outside wall and it will pull a steel plate up and down much like the bottom half of a sash window to open or seal of the extractor hole . Hope this helps if you need any more specific info please ask . I keep hearing the term wipers but can't find a answer anywhere??. Thanks Keith.
