Old Audio Mixer / Delay Effect IC
Ernst Eiswürfel
Joined Oct 29, 2018
16
Hello Community,
i have an audio mixer, the delay effect function works sometimes but not always, and i think i found the Problem, do you guys think the "NE571N" is the Problem of that? bc thats the only IC i found for the delay effect when im right.
AnalogKid
Joined Aug 1, 2013
12,254
There are almost zero passive components on that side of the board. Please post an image of the other side.
The OKI part at the bottom looks like a RAM chip (a memory device). The Toshiba part comes back as a quad NAND gate. Missing (at a minimum) are the A/D, D/A, and memory address counters.
There were bucket-brigade audio delay devices back when. Maybe one of them is on the bottom side.
ak
Ernst Eiswürfel
Joined Oct 29, 2018
16
ak
This is the underside.
28,127
The effect referenced as "Delay" was not actually a true delay in some devices, but rather a scheme to boost the gain as the signal faded. I think that was related to a "comply" function. The 571 IC was a gain controlled amplifier that could be made to provide that function. (It acted like a compressor to hold the output constant for a short time, much more like a sustain function.)
Unfortunately the 571 has been out of production for decades, with no exact replacement available that I have seen. Similar functions with much different circuits and more control are available from Analog Devices.)
Ya’akov
Joined Jan 27, 2019
10,291
Since that PCM54HP is a honking big 16-bit DAC I suspect the delay is digitally created so my first effort at repair would focus on the switch that controls it, assuming there is a hard switch.
35,093
The large square black IC in the 68-PLCC socket looks like a Motorola MC68HC11 MCU.
KM62256 is a 32KB RAM chip.
I am going to bet that the delay is done in MCU software.
Ernst Eiswürfel
Joined Oct 29, 2018
16
I think that too that the delay effect is generated digitaly, i think the delay slider is the problem i orderd that gonna test it when it arrives.
