Oil well ignition module
MarkySparky42
Joined Aug 28, 2022
204
So tomorrow I can stay late in the lab. Kids get the bus home. I’ll also bring the gear home so I can putter on Saturday. This is probably a bad case of me not using the digital scope correctly.
shortbus
Joined Sep 30, 2009
10,049
1000rpm approx.
While 1000RPM or even 500RPM may be the flywheel speed, it isn't the actual ignition or firing speed. This is a hit and miss engine, it has a governor that regulates the RPM output, after it fires the plug it may coast for a while to keep the speed constant, without firing the cylinder. All depending on the load on the output.
https://en.wikipedia.org/wiki/Hit-and-miss_engine The governor was typically like the fly ball type used on steam engines.
MarkySparky42
Joined Aug 28, 2022
204
I agree
That’s how it’s supposed to be
The governor rod was removed when this electric ignition module was installed. It runs pretty consistently- there is nothing to mechanically disengage the spark because it does not use the internal magneto. This is an add on magneto and magnet trigger.
now we are attempting to take it farther and get rid of the magneto and only use the magnet mounted the flywheel and the pickup coil to trigger a DC (solar and battery only) CDI circuit.
shortbus
Joined Sep 30, 2009
10,049
If that's where your going with this, I hope you have experience pouring and scrapping babbitt.:) Those engines were never meant for continuous firing.
Alec_t
Joined Sep 17, 2013
15,152
So, from the linked video we now know the engine is firing at ~5Hz. That's useful for the circuit design process.
Irving
Joined Jan 30, 2016
5,195
Breadboard set up
Looks OK as far as I can see...
Any opinions on this scope?
DEVMO Digital Oscilloscope Kit 2.4" TFT Handheld Pocket-Size DIY Parts Fully Assembled Electronic Learning Set https://a.co/d/3nUdH3s
Personally I think these are a waste of time, however if its all you can afford.... I'd save up for the next level up around $150
a resistor between the trigger and the scope
Hmmm not sure why that's made a difference... do you mean between the 555 output and the 'scope?
