Ohms Law Clarification Please
stinky111
Joined Apr 7, 2011
39
Hi all,
IF R1=13Ω, R2=42Ω R3=???Ω.
V=230Volts & I=53amps.
Calculate R3
Im familiar with using Volts & Amps to get Resistance Total, but not sure with above when given 2 of the 3 resistance values.
Using V & I to calculate I get:
Rt = 4.339622Ω
I thought it would make sense(in my head to) then -R1 & R2 values from Rt to give R3??
Is this correct?? Thx
bertus
Joined Apr 5, 2008
22,998
You can take an other approach to the problem.
You know the total current.
You know two resistor values.
With the given voltage and the two given resistors,
you can calculate the currents through these resistors.
You can subtract the calculated currents from the total current.
With this resulting current and the given voltage,
you can calculate the missing resistor value.
Succes,
bertus
Joined Apr 5, 2008
22,998
@dcarson7:
The homework help forum is to get help.
Please do NOT give complete answers anymore.
Only hints and suggestions to solve the problem are welcome.
@stinky111
You can take a look at this page of the eBook:
Simple parallel circuits
dcarson7
Joined Apr 28, 2011
7
@bertus - Advice noted. , when I said check RT with R3 value, I was hinting for the OP to make some effort there.
There was nothing asked regarding power but I felt it'd be wise to inform someone new that considerations needed to be made.
@Adjuster - solid point, anything high power I tend to run away from :)
