Octopus component tester query
Burt L.
Joined Apr 18, 2019
12
Having built up a simple octopus circuit, I connected it to my Siglent 1202XE.
So far I have been unable to get clear readings for open and short on the probes,
(horizontal for open and vertical for closed).
I'm new to oscilloscopes so likely it is my lack of knowing how to set up the scope.
I'm looking for a few basic pointers so I can get proper readings.
KeithWalker
Joined Jul 10, 2017
3,618
What is an "octopus circuit"?
A
Please show a schematic of the circuit you are using so that we can help you to get it working.
Burt L.
Joined Apr 18, 2019
12
What are you testing, what are the results and what are you expecting
Capacitors, diodes, zeners, transistors, electrolytic capacitors etc.
Right now I want to be able to see the horizontal line with test leads open and a vertical line with them shorted...
I'm pretty much OK with the circuit, it's the settings on the scope that are unclear to me.
Ya’akov
Joined Jan 27, 2019
10,298
Acquire Menu
Acquisition set to Eres
XY set to ON
Burt L.
Joined Apr 18, 2019
12
I think the issue's will probably be in your scopes settings. You should also let us know how you have it set up.
Before one can test any parts, the scope needs to be set up to read a horizontal line when the probes are unconnected and
a vertical line when shorted together.
I need some set up information to use the scope with an octopus. Are there some general settings needed to
use a digital scope with a curve tracer?
Burt L.
Joined Apr 18, 2019
12
If it's not clear, after setting the scope to the XY mode, you then adjust the two input sensitivities to get the desired pattern.
Thanks for all your input. I can see I have a big learning curve ahead of me but was able to
get the basic vertical and horizontal lines and angled line for a resistor and an ellipse on a small
electrolytic capacitor. Mostly I use an old Simpson 260 so this is all new territory for me.
Just learning all the functions will take some time so was glad to get some pointers in the right direction.
Thanks to all for chipping in on the subject.
all the best,
Burt
