Number of atoms in helium liquid
Kadav
Joined May 11, 2018
158
Hello I have a question in my exercise that I need to ask about .
the number of atoms in a helium liquid particle whose size is 0.708nm (I did not want to say lattice constant because I imagine helium liquid does not have a lattice structure because it is not crystalline.)
Another thing,I think we need to use the avogadro's constant but I dont know how to do it .
Thanks very much
Papabravo
Joined Feb 24, 2006
22,116
Thanks very much
On a periodic table of the elements you will find two numbers. The atomic number, equal to the number of protons in the nucleus, locates an element's position in the table. It should have elements with atomic numbers from 1 (Hydrogen) to the vicinity of 118 (Oganesson). The other number is the atomic weight. The units of the atomic weight are grams/mole. One mole of any atom or molecule is equal to Avogadro's Number. This number is approximately 6.02E23 and the weight, in grams, of one mole is just the grams/mole of the atomic weight times 1. I don't think it will help you with this problem.
If a figure of 140 pm is assumed for a helium atom, how many of those spheres can you fit in your droplet?
Hint: this problem is called "sphere packing". Look it up.
WBahn
Joined Mar 31, 2012
33,375
Thanks very much
What information do you have? Do you have, or are you allowed to look up, the density of liquid helium, for instance?
Going the other way, what information do you need that you don't have and how might you go about getting it?
