NTC thermistor
Missio2468
Joined Mar 18, 2022
74
I am designing a temperature monitoring instrument using 10k NTC thermistor. I have made the Circuit design which is pretty much linear for certain range(Considering calibration ) . The issue that I face is that the ntc thermistor has 5 % resistance tolerance which can give approximately more than 1 degree offset.I want my sensor circuitry to be as accurate upto 0.3 degree celcius. As of now I am using voltage divider with 5.62 k ohm resitor in series and measuring voltage across 5.62k ohm resistor.
Please help in designing the circuit to make it accurate.
38,458
You need to calibrate the circuit at a known temperature.
You could add a pot in series with one of the resistors to allow adjustment.
If you post a circuit schematic, we may be able to suggest better solutions.
Does the output go to a microprocessor?
panic mode
Joined Oct 10, 2011
4,964
"...which can give approximately more than 1 degree offset.I want my sensor circuitry to be as accurate upto 0.3 degree celcius."
what is the range? do you understand the difference between accuracy and precision? when you say "as accurate" it suggests that you are ok if result is within the same 1 degree C.
Ian0
Joined Aug 7, 2020
13,126
There's only one answer, and it's simple: buy a better thermistor. Epcos B57861S0103F045 has 1% tolerance.
If you have plenty of thermistors, then you could put several in series or parallel. If the error is distributed randomly, then the accuracy will improve with the square root of the number of devices used.
34,731
The difference between 5% and 1% tolerance refers to the variability from one device to another.
If you are making more than one unit and don't want to have to calibrate each unit then get 1% devices or better.
If you are building only one instrument then it does not matter if you use 5% or 1% device. You still need to calibrate the instrument over the full operating temperature range. Thermistors are inherently non-linear devices.
ag-123
Joined Apr 28, 2017
294
you can try calibrating with Steinhart–Hart equation
https://en.wikipedia.org/wiki/Steinhart–Hart_equation
as for thermistors, I've got a 3d printer kit where the delivered deemed 100k NTC thermistor measures 50k at the specified reference temperature commonly deemed 25 deg C. try that for 'accuracy', > 50% wrong.
The only way to use it is to calibrate it against the equation.
this may be likely to happen if one buys on the online "flea" markets, they always state 3950 thermistor with no further specs.
and it is a gamble, some of they are good and literally measures 100K if you ordered 100K, then there are the exceptions.
Missio2468
Joined Mar 18, 2022
74
Yes my circuit goes to microcontroller.
Also the 10 k ntc thermistor is in series with 5.6K ohm resistor(due to 33-44 degree celcius). 5V is applied and analog signal is taken across 5.6 k ohm resistor.
Missio2468
Joined Mar 18, 2022
74
Range is from 33 degree celcius to 44 degree celcius. I want my circuit to display temperature to precise to about 0.1 degree C
Missio2468
Joined Mar 18, 2022
74
Will think on that
Missio2468
Joined Mar 18, 2022
74
had tried out using stein-hart equation but I do not have any reference which can tell me different temperatures. Also the digital temperatures are not accurate as they seem for calculation purpose.
ericgibbs
Joined Jan 29, 2010
21,433
hi Missio,
This is a LTspice simulation of a typical NTC using the Steinhart–Hart equation.
What is the specification of your NTC thermistor.
E
Ian0
Joined Aug 7, 2020
13,126
You need three temperatures for the Steinhart-Hart equation to work.
Do you have a datasheet for your thermistor?
If so, look up the resistance values for 35°C, 40°C and 45°C and put them in the calculator.
34,731
The transfer function will be very close to linear if you keep the temperature range small enough.
How have you determined that your setup is not accurate enough for your purposes?
I can only assume that you are comparing your results against a known reference, e.g. a digital thermometer?
Hence you only need two pairs of calibration points, one at a low temperature and another at a higher temperature.
Post your calibration data, i.e. known reference temperature and ADC counts (not the temperature your unit is indicating).
ag-123
Joined Apr 28, 2017
294
to calibrate stein-hart equation
you would need a reference i.e. an accurate thermometer and to measure the temperatures and voltages and after that fit the equation against stein-hart equation to get the parameters A, B, C
there is an example, online utility as like mentioed by Ian0
https://forum.allaboutcircuits.com/threads/ntc-thermistor.187737/post-1743707
if one is 'lazy' to do that
quite commonly the manufacturer provides a B value for it e.g. 3950
https://en.wikipedia.org/wiki/Thermistor#B_or_β_parameter_equation
one way is to use the manufacturer prescribed B value work the equation to give temperatures.
then in the same way you would still need to calibrate it again by measuring temperatures with a separate thermometer and verifying its accuracy.
if you skip this calibration/verification step, then you are left with taking the manufacturer's spec for precision/tolerance e.g. 5% as far as the measurements goes.
note that while measuring say using an ADC, there can be wide band noise at the ADC input which is often RF (radio waves) signals, these can be as high as more than 10 mV which are often times represents more than a degree difference, especially if small voltages e.g. 3v range is used.
to deal with this it may be necessary to connect a capacitor so that it works as a RC low pass filter. this would reduce but not eliminate the RF noise problem.
Missio2468
Joined Mar 18, 2022
74
Thank You But have tried everything that is available on Internet. I don't want to calibrate everytime I change or replace my thermistor.
Missio2468
Joined Mar 18, 2022
74
Of course I have datasheet, But The issue is that I have thermistor with 5% resistance tolerance which can make my readings inaccurate upto 1 degree celcius. I want that to be 0.3 degree celcius . The other option is that I use thermistor with 1% tolerance.
