Hi everyone,
I am a mechanical engineering student and I need to develop an electric circuit. I designed the circuit with Pspice, but then I needed to implement it in Simulink. In the circuit, I have npn and pnp transistors (tip31c, tip32c) and in Simulink I cannot pick up the model of the transistor directly, but I need to specify some properties from the datasheet.
I am asked to insert:
- the forward current transfer ratio h_fe: in a datasheet 3 different values of h_fe are specified, and I do not know the difference among them
- Ic and Vce at which h_fe is specified: I found them in the datasheet
- output admittance h_oe: I guess it is Ic/Vce with the values of point 2
- Voltage Vbe: I found it in the datasheet
- Current Ib for voltage Vbe: in the datasheet I found Ic for Vbe, thus I divided Ic by h_fe. Is it correct?
- Reverse current transfer ratio: no idea about what it is, set to 1
- Collector and Emitor resistances: I have no idea where to find them
